Do you have a voltmeter? Pull the switch out & check for voltage at the coil or if there is a voltage dropping resistor, check for voltage on both sides of that. If voltage is good, take off distributor cap & dust cover. Take coil wire out of dist. cap & hold 1/4 inch from a good ground. Making sure points are closed, open & close points by hand. You should have a blue spark at coil wire. If no voltage at resistor or coil primary terminal, check switch & wiring to switch.
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
