Re: Farmall b n gen. to 12 volt. alt.
Posted by phil tibbetts on January 27, 2015 at 14:28:14 from (208.93.14.38):
In Reply to: Farmall b n gen. to 12 volt. alt. posted by showdown on January 27, 2015 at 11:37:15:
D beatty is correct, you need a smaller pulley on the Alternator to make it turn faster but that is difficult because they are usually pretty small to begin with. They do have regulators for those that will kick in at a lower speed. Have you tried running the tractor at full throttle? I have one on my 364 and I have to rev it up to make the alternator kick in. As soon as it does I can return it o low RPM and it will keep charging until I shut it off. To install a volt meter all you need to do is run 1 wire + to a wire that is only hot when the ignition switch is on and the other to ground.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
