Re: Super M-TA brakes glaze question
Posted by Janicholson on January 27, 2015 at 15:37:38 from (74.60.94.18):
In Reply to: Super M-TA brakes glaze question posted by Rex Simpkins on January 27, 2015 at 14:49:59:
Yes. if the material on the disks is nearly as good as new (ask for the thickness of the new disks, I do not know off hand) the total clearance should be .040 to .060", measured by putting the components into the housing in order, and measuring across the housing down to the first disk. A non-directional sanding with 200 grit paper will break the glaze. clean the ramps and balls. dry PTFE (Like Try-Flow) can be used there (just a little) on the balls and ramps. The housing needs to be machined at the surface where it mates with the tractor to reduce clearance. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
