Re: Electrical Issue With International Harvester Frame Is Hot
Posted by Janicholson on February 15, 2015 at 07:59:11 from (199.17.6.221):
In Reply to: Electrical Issue With International Harvester Frame Is Hot posted by Commoner#5 on February 15, 2015 at 07:38:28:
The negative side of the battery should have a
heavy battery cable going from a quality
battery terminal to ground (preferably on a
starter mount bolt. This battery cable should
be at least 2 gauge wire. It supplies the
complete ground system for the tractor. No
"extra" wires should be between those
connections. (I think this is the main issue)
From the positive terminal of the battery there
should be one battery terminal only hooked to
the same size 2 gauge cable, no other
connections.
The other end of this cable goes to the starter
relay (solenoid it is often called). That
relay should have 4 terminals 2 big and 2
small. The small terminals are labeled S and
I. (If only 3 all is well) The S terminal goes
to the push button for starting, 12 ga is good.
The big terminal close to the S terminal goes
to the above mentioned + battery cable. That
big terminal also has a #10 wire hooked to it
going to the amp meter (only there).
The Other big terminal on the relay goes to a
metal connector attached to the starter input
terminal.
The "I" terminal on the relay goes to the
ignition coil + side. It is to bypass the
ignition resistor giving the coil full voltage.
If this is not there we will worry about it
later, it is not needed if the coil is a full
12v coil with no resistor required. Get this
wiring correct and lets go from there. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
