Re: H Starter SLAMS Into Place
Posted by mkirsch on March 10, 2015 at 06:05:52 from (67.253.169.140):
In Reply to: H Starter SLAMS Into Place posted by FBH44 on March 10, 2015 at 05:39:00:
The only drives I know about are the conventional "Bendix" style with the spring, and a newer "clutch" type. Neither is specifically for "slamming."
I don't know what all the hand-wringing is about, though. You WANT the starter to engage positively when you hit the button.
All your wear and problems come from the starter not engaging completely, as in when it was on 6V.
As long as it is working properly, leave it alone.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
