Re: picked up a 3 pt tiller today
Posted by Tiller on March 25, 2012 at 00:16:33 from (68.149.42.239):
In Reply to: Re: picked up a 3 pt tiller today posted by Mike (WA) on March 24, 2012 at 13:32:23:
Doubt it's a Maschio as they are more heavy duty. About 90% of tillers are made in Italy and there's probably a dozen or so different brands. Can't tell if it's a chain drive or gear drive but check to make sure the oil level is at the right level before you use it. Also good to have a slip clutch or shear pin on the drive shaft.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
