Re: OT Coleman Generator Question
Posted by Bob M on July 09, 2012 at 19:11:46 from (65.110.154.2):
In Reply to: Re: OT Coleman Generator Question posted by Wesley Stephens on July 09, 2012 at 18:52:20:
So long as the generator did not run too long with the armature rubbing it'll simply "shine up" the armature poles and field shoes a bit - there should be no permanent damage. Be sure to blow out any metal shavings, etc. inside however!
A bigger concern is the molded plastic end bell. If the bearing has spun it likely chewed up the bearing cavity which generally ruins the end bell. Unfortunately the only fix is replacement
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
