Re: 4230 John Deere fuel
Posted by Steve@Advance on March 26, 2014 at 17:16:38 from (108.245.66.82):
In Reply to: 4230 John Deere fuel posted by David Parman on March 26, 2014 at 12:55:34:
Are you sure the lift pump is good? If it pumps like it should right after blowing out the lines it's probably not the problem, but worth checking.
Like jdemaris said, pull the stand pipe and clean it out. That should also drain out anything in the bottom of the tank. Maybe give it a stir and flush while you're there.
Depending on what you get out of the tank will determine if the ash is getting in there. I doubt you'll find much, but if you do look for possible entry ways, like around the sending unit or a damaged cap. Unless you get something really nasty out the tank, just a flush should clear it up. Having a radiator shop clean it is pretty extreme, mostly that's for something that has sat with gasoline for years.
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
