Posted by MarkB_MI on July 20, 2014 at 17:00:05 from (70.194.11.226):
In Reply to: Re: Hot water heat posted by Case e on July 20, 2014 at 11:27:02:
Adding central air to a house with hydronic heat can be very expensive due to the ductwork, so it's not surprising they put in heat as well. The incremental cost of a furnace would not be much over the central air.
Is that a gas furnace, or electric? If it's gas, you probably don't need to worry too much about replacing the boiler. But if the forced-air heat is electric, better figure on replacing the boiler.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp
... [Read Article]
