Re: what is the strongest 540 pto
Posted by mkirsch on August 18, 2014 at 07:43:31 from (72.45.143.81):
In Reply to: what is the strongest 540 pto posted by john stuver on August 17, 2014 at 06:10:25:
You'd need a 200-250HP tractor for that to work.
Horsepower is based off RPMs. Run the tractor at half speed, and you are making something less than full power. Possibly less than half power depending on the HP curve of the engine.
At 1/2 of rated full load RPM let's say the tractor does make exactly half its rated HP. So to get 100HP, you need a tractor that makes 200HP at rated RPM.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
