Re: 8N not starting
Posted by old on February 22, 2015 at 15:17:14 from (209.86.226.56):
In Reply to: 8N not starting posted by B W in Mo on February 22, 2015 at 14:35:55:
How are you checking the cap and rotor for cracks??? Many cracked caps or rotors can be cracked in such a way you can not see the crack. Also telling use if you have a front mount or side mount distributor and if 6 or 12 volts helps us help you. If you have a side mount pull the center wire out of the cap and spin it over and see if you have a good blue white spark that jumps a 1/4 inch gap or more.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tractor Profile: Allis-Chalmers Model G - by Staff. The first Allis-Chalmers Model G was produced in 1948 in Gasden, Alabama, and was designed for vegetable gardeners, small farms and landscape businesses. It is a small compact tractor that came with a complete line of implements especially tailored for its unique design. It featured a rear-mounted Continental N62 four-cylinder engine with a 2-3/8 x 3-1/2 inch bore and stroke. The rear-mounted engine provided traction for the rear wheels while at the same time gave the tractor operator a gre ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
