Tractor Talk
Re: Re: Re: Ford 900 electrical problem
[ View Follow Ups ] [ Post Followup ] [ Return to Tractor Talk ]
Posted by Harry on August 27, 1998 at 05:21:31:
In Reply to: Re: Re: Ford 900 electrical problem posted by Rod Carsten on August 26, 1998 at 20:47:04:
I suspect you are right on the amp meter connection. It should reflect what your external voltmeter shows on the battery. I would reverse the connections and see what it does. Your second question about the resistor is a bit vague. You should measure the voltage across the resistor, ie positive lead on side nearest battery and negative lead on other side. The purpose of the resistor is to drop half the supplied voltage. You may just be measuring it wrong. Is your coil a 12 volt coil? Normally the resistors are there to protect the coil not the points. Six volts will drop across the resistor and the remaining voltage across the coil primary. Hope this helps.
Post a Followup
: Re: Re: Re: Re: Ford 900 electrical problem
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
