Re: Unstyled JD A Governor Issues!
Posted by Steve@Advance on September 02, 2015 at 08:04:40 from (108.245.66.82):
In Reply to: Unstyled JD A Governor Issues! posted by Navajo350 on September 02, 2015 at 04:22:00:
You can't adjust the governed speed by changing the length of the throttle rod. The speed is set by the amount of pull on the spring in relation to the position of the hand lever.
With the hand lever set for idle, the rod should be just long enough to push the throttle plate closed. If you try to over ride the governor, you should feel it try to push the throttle back closed as the RPM come up. If you don't feel this happening, either the rod is out of adjustment, of the governor is not working.
Once you get it to the point you feel it work, set the spring tension so the RPM won't exceed the rated RPM with the hand lever set at full speed.
You can then watch it work. When set for full speed, over ride it back to idle. Release it, the throttle should go wide open until the engine comes up to speed, then the gov will throttle it back to maintain rated RPM.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
