Re: Buying my first tractor. Questions and advice needed.
Posted by mikestilly on January 01, 2016 at 12:57:03 from (98.224.175.114):
In Reply to: Buying my first tractor. Questions and advice needed. posted by mikestilly on December 28, 2015 at 09:16:01:
I bought the Ford 3000 for $4200. Definitely felt it was a great deal. The tractor had no leaks from what I saw and we drove it around and looks to be in great shape. No hydro leaks or anything that stood out. Started right up but was stored in a heated garage. He said in cold temp just need to use the block heater. He said some filters need replacing and a pin and nut in the loader arm because the one there doesnt look correct and has a small amount of play. We're going to check on sunday to see if it will get stuck on the turf tires in the muck. Will use the loader to get free.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
