Re: Custom made LP fuel level gauges for tractors
Posted by Determined on December 08, 2016 at 06:11:08 from (216.130.212.213):
In Reply to: Custom made LP fuel level gauges for tractors posted by matthies on December 06, 2016 at 17:17:19:
If you do a search for (fuel gauge sender propane tank)
You will find various makers of the part you are after.
Different brands have different mounting patterns so you will have to match up what you have.
Next you will have to choose one that will work with the dash gauge you have.
Common ones are 0-30 ohm and 0-90 ohm.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
