Re: OT wiring an AC lamp socket
Posted by Steve@Advance on December 21, 2016 at 13:02:10 from (24.182.105.179):
In Reply to: OT wiring an AC lamp socket posted by Dave H (MI) on December 21, 2016 at 11:43:15:
Being the wiring is that old, good bet that is only a 2 wire system with no ground.
To determine which is the "hot" wire, you'll need to ground one lead of the volt meter to something metal that is in contact with the ground, like a water pipe, metal siding, etc. Then touch the other lead to each wire. The one showing a reading, 110-120vac will be the hot.
Be careful disturbing that old insulation, trust nothing!
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
