Posted by bhb on November 05, 2018 at 07:13:05 from (76.189.66.166):
I have a Case 580 Super E backhoe that started running rough. I had the injectors repaired and it ran better, especially at idle. The man that did the work said that if it idled better but still ran rough at higher speed when it needed more power, that was common with the Lucas pump and bring the pump in. After he went over the pump it was better the engine still vibrates at a higher speed, (between 1500 and 2000 rpm). He does work for Southeastern, other tractor companies and truck repair companies. Here is what I have done so far, replaced the air filter, both fuel filters and tightened all fittings. I have two people give different opinions one was a bent push rod, I checked the valve clearance they are all to the manual specs. The other who has worked on these machines said that the fuel lines could have a small wear hole that would cause it to suck air. I would think with the high pressure fuel would leak out of the hole. He said he has changed many of the lines. I am at a loss as to what to do. If the fuel lines could cause this I will replace them. The machine is not near any diesel repair shops and would have to be transported. Thank you in advance Bill
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and
... [Read Article]
