Several things I can see, first of all I think that you have a RWA disc not KBA. Second you have the wrong hydraulic cylinder on it. You need a 8 inch stroke with double acting pressure so as to get the wheels up out of the dirt so when you are disking the dirt that the disk is throwing does not touch a wheel and leave a ridge. Next you can throw away the stones, bricks and firewood as the wheel frame should be all you will need for weight. Next comes the leveling screw on the tongue needs to be adjusted so that the front gang is deeper and the back is shallowed up till it is level. Also you will need to use it till the blades all get scoured and clean and that none of them are partially loaded. All scrapers must be properly adjusted to keep blades from loading. Without a furrow filler attachment you will always have the outside rear furrows but the next time over or a pull behind drag of any kind will level those out. Hope this helps. Tom
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor.
... [Read Article]
