Re: Can't get temp. sender out of Ford 801 tractor...
[ View Follow Ups ] [ Post Followup ] [ Return to Tractor Talk Discussion Board ]
Posted by Gerald on December 08, 1998 at 07:12:27:
In Reply to: Can't get temp. sender out of Ford 801 tractor... posted by Herb Wheeler on December 07, 1998 at 19:20:50:
: I have a Ford 801 tractor. I'm putting in a new temperature gauge due to old one was broke. The trouble is I can't get the sender out of the block. Is there an easier way to do this? I have tried vice grips and pipe pliers but it still doesn't move. The owner before rounded the hex head off too much to use a six point socket on it. Any help is surely apprieciated. Thank you for any help. Herb
Apply Kroil from Cano Labs. Let it soak a day, the applyl the vice grips, turn a little in sometimes helps break things loose. If you break it off them drill it with a carefully centered tap drill for the pipe thread and you should be able to get the pieces out and clean the threads with the pipe tap.
Gerald
Post a Followup
: Re: Re: Can't get temp. sender out of Ford 801 tractor...
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
