The reduced size is supposed to help with preventing the problem you are encountering at this time. It is smaller to give clearance for removal. I like diesel fuel for these jobs it soaks in better than anything I have tried. If you want to mix a bit of old engine oil in with it fine. Then just keep soaking for a few minutes then go do something else for a few hours. If no joy after trying this put a weight behind the fork and drive it out with a big hammer. The bigger the better you don't have to swing as hard, and if it moves it moves easier. If it doesn't move it will do no more damage than pounding repeatedly with the small useless hammer. I like 2-4 pound hammers for those reasons. If somebody can be twisting the bolt as you hit may do more than anything for it. Heating then cooling with water will crack the rust loose and will also tend to harden the pieces too.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp
... [Read Article]
