fuel tank leaking again
Posted by 37 chief on April 08, 2021 at 21:51:41 from (68.8.190.72):
My JD 401 B fuel tank started leaking a year or so ago. VC cummings was correct he said it will leak again if I try to fix it. I took it to a radiator shop. They soldered up the crack. The crack is on the front of the tank. Nothing rubbing to male a hole. It is just a small crack right in the open. In a few months it started leaking again. I tried JB Weld it held for a while. Now it is leaking again. All I can do now is JB weld again. I guess I will start looking for a used tank. Part no AR72996
The air cleaner hangs off the center. That may be causing the vibration. may see about mounting it different. Stan
Today's Featured Article - Tractor Profile: Allis-Chalmers Model G - by Staff. The first Allis-Chalmers Model G was produced in 1948 in Gasden, Alabama, and was designed for vegetable gardeners, small farms and landscape businesses. It is a small compact tractor that came with a complete line of implements especially tailored for its unique design. It featured a rear-mounted Continental N62 four-cylinder engine with a 2-3/8 x 3-1/2 inch bore and stroke. The rear-mounted engine provided traction for the rear wheels while at the same time gave the tractor operator a gre ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
