Re: Older Tractor Slow Enough For Rototiller
Posted by glennster on May 08, 2021 at 19:08:48 from (99.90.9.201):
In Reply to: Older Tractor Slow Enough For Rototiller posted by jtelander on May 08, 2021 at 16:31:02:
i run a 6 ft gear drive rural king tiller behind my international 240 utility. no live pto, 1 st gear at pto speed. if the ground is real hard, i make two passes. i run a chisel plow innthe fall to break up the ground. heres a couple pics. the 240 has a fast hitch with 3 pt prongs.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
