Posted by Steve@Advance on August 22, 2021 at 17:41:31 from (99.190.215.237):
In Reply to: Ford 841 update posted by grandpa Love on August 22, 2021 at 15:44:17:
If it still has the stock coil, the wire wires will work. Only with the flame thrower coils are resistor wires required, so I hear. But wire wires will not make it run bad, they are hard on the electronic unit.
Rapid, rhythmic popping back through the intake, worse under load or acceleration is usually caused by an exhaust valve not fully opening, a flat cam. Did you watch the valves opening while the cover was off?
It can also be cross firing, a carbon tracked distributor cap, really bad plug wire insulation between to wires touching each other, usually worse when damp.
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si
... [Read Article]
