Re: I H 1086 3pt hitch
Posted by pete 23 on March 04, 2022 at 11:48:32 from (173.84.76.41):
In Reply to: Re: I H 1086 3pt hitch posted by fixerupper on March 04, 2022 at 06:36:24:
The rockshaft will hit the inside of the top cover before the piston can come out of it's bore
unless something has broken or fallen apart. If a cotter key comes out it is possible for the
piston rod to fall out.
You always adjust a hitch height with no load on hitch so you can be sure it is possible to lift
the hitch manually at least one more inch so the rockshaft does not hit cover when hitch is fully
raised.
I have seen pistons come out, cover broken from rockshaft banking against them like when backing
up a semi mounted plow to clear trash out of it. Spanking new 1466 to be exact.
Also, tires catching on hitch and slamming it up and down when hitch is not being used.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
