Re: CAR ENGINE IN TRACTOR ??
[ View Follow Ups ] [ Post Followup ] [ Return to Tractor Talk Discussion Board ]
Posted by Gerald on January 31, 1999 at 00:54:15:
In Reply to: CAR ENGINE IN TRACTOR ?? posted by geln on January 30, 1999 at 09:37:05:
My uncle Carl tried that about 40 years ago. Power wasn't the problem, engine cooling was. At the low speeds of the tractor engine speeds the car water pump doesn't seem to move enough water. He felt that the car moving through the air added significant air cooling to the block also. Probably any car or truck engine put in a tractor should be used with a larger crankshaft pully and smaller water pump pulley to make the water pump move more water. Wouldn't hurt to make sure the hoses were as large, short and straight as possible.
Gerald
Post a Followup
: Re: Re: CAR ENGINE IN TRACTOR ??
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
