Tractor Talk Discussion Board |
Re: Diode in alternator system
Posted by Joe (Wa) on March 05, 2005 at 20:56:15 from (67.5.135.39):
In Reply to: Re: Diode in alternator system posted by jdemaris on March 05, 2005 at 20:11:00:
You can go low tech on this thing for a quick check. Disconnect the neg (or pos) battery terminal, series a 12v light between the battery cable and the neg post. Use an indicator lamp or other bulb 1 amp or less. If the lamp lights full bright you know you are leaking current at the amp rating of the lamp or more. Takes many days at 1 amp or less draw to run down a 600-800 AH battery. If the lamp doesn't light the drain down problem is in the battery, low alt output, or your run time is not long enough to recover the battery from starting and normal run use. If the lamp is lit, isolate unswitched terminals first as close to battery source as you can till the light goes out. If lamp is still on, lift the power-in terminal on switches. Lamp still on, you've got a leak to gnd between the battery and the terminals that you have lifted, may be a skinned wire rubbing on the frame, etc. There can be 2 of more leaks to gnd with enough current to keep the lamp lit, so leave all terminals lifted until the lamp is completely out. As you connect the terminals back up keep an eye on the lamp. Joe
Home
| Forums
Today's Featured Article -
An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si
... [Read Article]
Latest Ad:
18-32 Case Cross Motor
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
