Re: Got any tricks to remove a stuck head bolt stud?
[ View Follow Ups ] [ Post Followup ] [ Return to Tractor Talk Discussion Board ]
Posted by B.C. on July 22, 1999 at 06:04:58 from (131.167.75.193):
In Reply to: Got any tricks to remove a stuck head bolt stud? posted by Jimbo on July 21, 1999 at 23:09:11:
If all else fails, and I do mean all else, cut the stud off flush with the head. Drill down the center of whats left with a small, then progressively larger drills. At some point you should approach the minor diameter of the tapped hole and then you can take a punch or chisel and rotate what's left out.
Some people have suggested moderately heating studs and dripping candle wax down on the stud. The wax is supposed to be drawn down into the thread area, but I never had much luck with it.
Post a Followup
: Re: Re: Got any tricks to remove a stuck head bolt stud?
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want … unless you own a monster tractor. U ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
