Re: Property lines survey or gps?
Posted by sshev on October 20, 2006 at 04:58:20 from (206.72.54.238):
In Reply to: Re: Property lines survey or gps? posted by cannonball on October 20, 2006 at 03:45:45:
no you don't "loose" any land measuring with GPS. as I said Global Positioning is mearly a newer method of measurement. Surveyors have always used "plumb" or level distances in there measurements, not along the surface of the ground if there were significant elevation changes. When measuring by hand was replaced by electronic total stations which use infrared light reflected off of a prism to measure distance, the instrument also measured vertical angles and corrected internally for horizontal distance.
Scott
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
