Re: Wagon Running Gear Size
Posted by JWC in MS on April 11, 2007 at 15:46:40 from (199.133.90.83):
In Reply to: Wagon Running Gear Size posted by Jeff C. in Marion, Oh on April 11, 2007 at 13:19:34:
5 lug with 15” rims or narrow 16” rims will run from 3 to 5 tons, 6 lug will be 5 to 7 ton unless they have very heavy rims and 10 ply or heavier tires, 8 lug has a wider range. Any wagon will not have a heavier weight rating than the total weight rating of the rims or tires whichever is least. There are many old hay, corn, cotton and other running gears still in use over 50 years old. The wear in the steering linkage on an automotive type steering wagon will greatly impact how fast it can be safely pulled. The wear on the kingpin of a 5th wheel steering wagon can be a hidden problem. A good rule would be to start with your tire capacity (assuming they are in good condition and are the right size and type for the rims) and cut back according to the wear in the steering, hitch points etc. Wagons do not transfer any weight to the towing vehicle and very few have brakes so don’t load more than you can stop or steer. If you post here and mention the # of lugs, the rim size, tire size and the brand you can be given a better estimate. Don’t forget to take include the weight of the gear, bed and tires is included in the load capacity.
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
