Re: postive or negative ground
Posted by bc on May 10, 2009 at 10:51:41 from (71.158.222.135):
In Reply to: Re: postive or negative ground posted by Gerald J. on May 10, 2009 at 09:08:54:
Not necessarily on the cable and post size. I see alot of situations where someone has replaced both cables with extra long cables off the parts store rack of the same color, usually more all red than black. And then the battery is gone and/or the batteries are in a position where the battery can be twisted/turned end for end so you can't tell which cable is supposed to hook to what post. An old tractor sitting somewhere with no battery, I could figure it out but nothing wrong with the question here.
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want … unless you own a monster tractor. U ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
