Re: Chevy truck mechanic
Posted by 55 50 Ron on November 03, 2009 at 11:16:56 from (206.8.2.145):
In Reply to: Re: Chevy truck mechanic posted by BDT in Minnesota on November 03, 2009 at 08:50:01:
Yes, I replaced it with a new brass plug. But the old one was brass also.
To get the old one out I used a couple of different diamond cutting bits in an angled drill and cut away part of the boss on the block. Sprayed with Kroil a few times and let it set. One diamond cutting bit was 1/8 inch diameter and with it, I cut straight down from the top until that bit was into the center of the brass plug where the broken off drill bit remained. Then I squeezed gently from the sides with a small visegrip pliers and the brass plug sides moved inward just enough to be able to turn it slowly. Then it was easy to pull the broken bit out. Ran a tap in the boss threads and put in the new plug. The block is still full of crud, but I'll get that cleaned another time.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
