There are several different kinds you can put on it. First off loaded tires to the inside, A-C made a hub that bolts the the tractors rim and the dual bolts up to it in the center. Now as far as the rest go, there are several types of clamp on duals that use a 5/8 J bolt. There are T Rails, clamp on, And fixed bolt rims. These all use J bolts that hook to the slide rails on the tractor. The tire size should be the same on the tractor and duals. A 15/16 wrench or deep well socket will tighten them up. Bandit
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
