Re: stuck clutch revisited.....thoughts on this idea
Posted by NCWayne on June 23, 2010 at 11:54:57 from (166.82.79.195):
In Reply to: stuck clutch revisited.....thoughts on this idea posted by glennster on June 23, 2010 at 05:59:45:
While I understand that a clutch disc can stick to the input shaft that alone will not cause it to stick like your describing so penetrating oil isn't likely to do alot of good beyond getting into the lining. That said, and knowing that it has a loader on it take it to the field and bury the bucket in the ground and try to get a big bite. When the rear tires start to spin hit the differential lock so both rears spin and then hit the clutch. Between the force of the engine turning everything and then the stuttering action caused by the tires spinning (I assume it has chevron tread tractor tires or something equilivent)it should break the clutch free. Once free all you need to do is ride the clutch a bit and let everything polish itself out and you should be fine. Granted you might cut a season of use off of the life span but it beats having to break the tractor in half just for it being stuck. I've seen alot of clutches stuck over the years and doing what I just described, be it with a buried loader bucket or putting a push bar against a tree, I have never had one that won't release eventually. Too, if possible, you might also want to put the drawbar against something and try the same scenario in reverse. Sometimes I have found if it didn't work in forward that alternating between fwd and rev would work...sort of like bending a piece of metal back and forth to break it off. Good luck.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
