Re: alternator
Posted by ludgyy on January 17, 2011 at 22:03:46 from (50.48.48.105):
In Reply to: alternator posted by Gary Polivka on January 17, 2011 at 18:45:22:
Generally with tractor applications you want a smaller pulley because tractors run at a much lower rpm then a car. An alternator will produce the same voltage at different rpms, what actually varies is how much amperage the alternator will produce at a given rpm. With a tractor that just needs the battery(s) maintained and a few lights run, the pulley size doesn't need to be to exact just as long as it is spinning close to the desired rpms.
A delco alternator can be run the opposite way as what it is intended for and still work, however if too much load is put on it running backwards it can possibly overheat. again, with a tractor that just needs the battery maintained and maybe lights every once in a while it would be fine.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
