Re: Gasoline - $18 per gallon! Holy Cow
Posted by camju on January 19, 2011 at 17:22:17 from (142.161.9.65):
In Reply to: Re: Gasoline - $18 per gallon! Holy Cow posted by 730d se on January 19, 2011 at 12:22:15:
I have NEVER used anything but tap water from maney different wells,Even out of a puddle once.I run most vehicles till the are in the bush,My dad also.I can' not recall ever changing antifreeze or having engines over heat.Many trucks over 200000 miles before they end up in the bush,mostly from to many trees in the bush.I have a 1995 Volvo semi that has 4 cups of black pepper in it(to seal a leaking water pump) been running that way for a long time,now is parked because the trans lost 5th gear.1.8million miles never had a water change.When we do any mechanics on vehicles and have to drain the water it always gets screened and poured back in.And I have never herd of having to mix antifreeze with water before adding to rad...THAT IS ABSURD.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
