Re: Ford 5000 hydraulic system
Posted by paul on January 31, 2011 at 17:22:16 from (66.44.132.120):
In Reply to: Ford 5000 hydraulic system posted by Chief A on January 31, 2011 at 15:20:10:
The 3rd set of remotes is plumbed very special, to only work in draft mode, it will lower & raise a semi-mount plow with the 3pt lever. It is a Ford feature, extra on some tractors. I did not know a 5000 could have that, you must have a late model one.
You do not in any way, shape, or form have 3 remote hookups. You only have 2.
That 'extra' one will not ever work as a 3rd one. It's just hanging there waiting for a semi-mount plow to work only in 'draft' mode to keep the plow level for you with less fuss & adjustment on your part. It also requires a special Ford hyd cylinder that needs the shaft turned in one direction to line up with an arrow - it does not work with a regular hyd cylinder on the plow. There is likely an extra knob or lever to fine-tune the 'draft mode' for the proper response.
My dealer figured well over 80% of these sytems were never used. I plowed with my 7700 & not TW-20 since 1980, and have never ever bothered to set it up.
It's a throw-back to the Ford 100 series and the 3pt draft control. It goes one step farther, and includes controlling the back end of a bigger plow.
You only have 2 remotes on your tractor, and will need to rig up an electric control to power a 3rd set, or some other deal. You won't never get that extra set of couplers to run anything as a 3rd remote.
--->Paul
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
