Re: rear brakes won't bleed
Posted by wally_mi on April 15, 2011 at 04:40:35 from (64.136.27.226):
In Reply to: rear brakes won't bleed posted by farmer boy on April 14, 2011 at 20:40:42:
farmer boy,
i had a 92 with the same mc. if you got air in the mc it had to be bench bled. the angle of the mc in the truck will not bleed out completly. your parts man can explan better than i can. if you can't bleed the front bleeders you might try to loosen the lines. carefull you don't twist off the lines. good luck. wally
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
