Re: Changing fan belts on Farmall A
Posted by gene b on July 13, 2001 at 15:30:34 from (63.15.137.179):
In Reply to: Changing fan belts on Farmall A posted by LarryE on July 13, 2001 at 13:35:44:
hope you didnot turn the nut that is closest to the block as it is made to seat in the slot of the bracket the nut next to the fan is the one to be loosened the belt is put on over the blades while you are at it I would put on a new fan belt the fan belt is 17/32x26-1/2 work the belts over the fan and into position that way the gen belt goes on first
Post A Followup
: Re: Re: Changing fan belts on Farmall A
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
