getting a W-6 (248ci.) to idle down.
Posted by Charles McNelly III on March 04, 2007 at 12:57:10 from (65.150.172.58):
Hi everyone, I seem to be missing something here, I can adjust the idle screw all the way out and cannot seems to get the motor down below 1030 rpm. I checked for vacuum leaks, none. I checked to see if the throttle shaft was out of the groove on the carb, it wasn't. I pulled the governor side plate off and backed the low speed screw out to the point it wasn't touching and nothing seems to let the motor drop down to a decent idle. Any ideas???
Thanks,
Charles
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
