Re: getting a W-6 (248ci.) to idle down.
Posted by farmallhal on March 04, 2007 at 14:18:21 from (64.85.221.207):
In Reply to: getting a W-6 (248ci.) to idle down. posted by Charles McNelly III on March 04, 2007 at 12:57:10:
Charles, I had the same exact problem on my M when I first got it. I just opened up the governor and adjusted the two adjustment screws, one is the idle stop screw (top one) and the speed adjusting screw (bottom one). I used the detailed directions in the service manual for my adjustments. Been running correctly ever since. There is another adjustment that can be done inside the slanted cover at the front of the carb throttle shaft which might be your problem. There are some other adjustments noted if for some reason you can't get it adjusted with those adjustments. If you don't have a manual maybe someone will jump in here with their solutions. Good luck, Hal.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
