Re: Farmall A Zenith Carb questions
Posted by El Toro on March 07, 2007 at 06:54:29 from (205.188.116.133):
In Reply to: Farmall A Zenith Carb questions posted by Chad from Michigan on March 07, 2007 at 06:24:28:
My manual has your carburetor listed, but it doesn't give the float setting. That screw that you are adjusting is for idle only. Turn CW to enrich and CCW to lean. Wasn't there a float gauge with the kit? It has the the 1-1/4 Updraft listed, but it's not shown or which tractor it was used on. The float setting for that is 1-5/16". Make sure your intake manifold is tight and the carburetor is snug, don't over tighten.
Your float level is probably too low. These carburetors don't have the main jet adjusting screw that's used on the H Farmalls and up used to enrich the carburetors. If you have an inline
fuel filter I would remove it since a lot of those are not for gravity fed engines. Hal
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
