Farmall A Zenith Carb questions
Posted by Chad from Michigan on March 07, 2007 at 06:24:28 from (152.72.151.71):
Ok I have a 1946 A with the Zenith Carb. I see on one web site there is 2 different zenith Carbs.
My carb #'s are 52499, 9752, DB
Well I got the bowl gasget from the dealer and cleaned the carb real good. Now I got the tractor to run but it is slow and spits and sputter some when I advance the throtal. I am guessing it isn't getting enough gas. I Know I need to check the sediment bowl screen. The inlet screen in the carb is nice and clean.
Ok there is a adjustment screw in the top of the carb that faces the front of the tractor. I can screw that in or out and it doesn't make one bit of difference in the engine. Do I have plugged passage way? what does this screw do?
Also does anyone have a info sheet on settings for this carb? Float levels and such?
Thanks for the help.
Chad
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
