Re: Farmall A Zenith Carb questions
Posted by Chad from Michigan on March 07, 2007 at 07:05:12 from (152.72.151.71):
In Reply to: Farmall A Zenith Carb questions posted by Chad from Michigan on March 07, 2007 at 06:24:28:
I didn't buy a replacement kit. The only bad thing most of the time is the gasket. I took and soaked the carb it looks new. Took out each jet made sure it was clean completly tore it down and used compressed air to blow it out.
I need to replace the needle and seat it wont stop the gas. Even with the sediment bulb off it leaks as well so I have a coffee can under the carb right now.
I get no difference in engine performance adjusting that screw and it seems like you would see something or hear the engine? am I worng on that?
On my cub Carb float I have settings for both directions on the float amount of drop and the closed postion.
Chad
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
