H engine timing
Posted by Tom Windsor on March 24, 2007 at 21:13:59 from (69.40.61.69):
I have been workling awful hard to rebuild this H engine. So far, I am real happy with where I am. It is now on the engine stand with new pistons, sleeves, rings, mains, rod and cam bearings, except for the flywheel, the rear end is built up, Oil Filer canister installed, lifters in, head rebuilt and ready to install and side covers are on and now I am down to the front end.
I want to make absolutely sure as to the timing of the gears there.
There are 5 gears:
1. the Distributor drive gear
2. The cam gear
3. The gear on the crank
4. An idler gear
5. Govenor drive gear.
As I understand it, I need not be worried with timing on 4 and 5 above cause it is not necessary but that I must get 1,2 and 3 done correctly.
Will one of you who is an expert on the timing, walk through this with me one more time?
TW
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
