Re: A-Running better, but losing power under load
Posted by Joe Schmitt on April 06, 2007 at 14:27:41 from (216.222.172.77):
In Reply to: A-Running better, but losing power under load posted by kazenza on April 06, 2007 at 12:22:14:
Check to se if you have a good stream of gas to the carb, sometimes a restiction in the tank valve will allow enough gas to idle with no load but not enough when it gets into a pull. Take the line off at the carb and let the gas run in a pail for a while ,if it peters out your valve is plugged.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
