A-Running better, but losing power under load
Posted by kazenza on April 06, 2007 at 12:22:14 from (69.225.242.87):
My 47 A runs smooth at idle, but sputters moving up to higher rpms and loses power dramatically under load (sputtering quite a bit in the process and sounding like it might die). Running it with the woods mower on it barely runs, sputters a lot, and then occasionally revs up some and sounds more normal. I have a new carb, magneto, and manifold. Adjusted the mixture to where it's running smooth with no smoke. Appears to be running on all 4 cylinders.
On a related note, the throttle lever doesn't seem to have much effect on engine speed after the tractor is warmed up. I just replaced the throttle return spring. Is this an issue with the weights in the governor?
Randy, Jamestown
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
