Re: A-Running better, but losing power under load
Posted by Roger Mills on April 07, 2007 at 08:02:40 from (71.213.65.16):
In Reply to: A-Running better, but losing power under load posted by kazenza on April 06, 2007 at 12:22:14:
If you have the old carb and mag-try swapping them back in one at a time to see if either helps. A new mag can have a bad condenser as many are bad from new. A new carb can have sticking floats as thay are not run tested. A new carb on an old fuel system can get plugged immediately so check it. Check to make sure the manifold is seated and not leaky. Unlit propane torch at the intakes will tell you.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
