Re: 160 degrees on a C-123 block! :)
Posted by Patrick Martin on April 07, 2007 at 22:50:45 from (64.154.26.250):
In Reply to: Re: 160 degrees on a C-123 block! :) posted by Patrick Martin on April 07, 2007 at 22:47:24:
"As long as the coolant isn't boiling; you're not going to hurt the engine. Getting the temp up into the 180 to 195 range is BETTER for the engine than running cold.
Yep I know it needs to be hot to maintain combustion but I wasn't sure what the parameters of this cooling system were. I wish I could find an IH specified temp range for this little engine. :)
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
