Re: 160 degrees on a C-123 block! :)
Posted by Bob on April 07, 2007 at 23:49:15 from (69.178.229.154):
In Reply to: Re: 160 degrees on a C-123 block! :) posted by Patrick Martin on April 07, 2007 at 22:50:45:
In the "old days"; before "permanent antifreeze" was in common use; they tried to keep coolant temperatures down so as not to boil away the antifreeze.
As long as the temp stays below the point where the coolant will boil in "hot spots" in the engine you aren't going to hurt the engine; and the engine will probably burn cleaner AND last longer.
That pretty much applies to ANY liquid-cooled engine.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
