Super A Sickle Bar Mower A-21 / A-23 Question
Posted by Mark (PA) on April 18, 2007 at 17:17:02 from (207.255.75.181):
Hello,
I am in the process of rebuilding my Sickle bar mower that mounts on the rear of my Super A. I am going to be using it to cut about 20 acres of hay this year. I have replaced all the knives and some of the hold downs. After doing some research and checking my sickle bar I have found that I believe most of the rock guards are bent. When I first thought of bent I assumed bent enough a person could tell but after looking I assume you guys mean bent could be 1/4" low or high or something which isn't that obvious without a level. SO tonight I used a level and found almost every other guard was off. So I assume the cutter won't cut real well like that. I did try it though and it really didn't do too bad but I found it bound up fairly easy (of course this is before I read that you shouldn't be in first gear when using a sickle!)
Ok all that aside! My question is. The gentleman I got the mower from gave me 3 brand new OEM guards. I can actually read the part marks. The guards on the sickle I cannot. The guards he gave me are MC2043 and MC2041. Which I read in the manual is for a "weed" bar. So when I go to my dealer should I ask for those or should I get the "regular" guard which is listed as an MF989?
I have also had people tell me to get IH double guards and put on it?
Lastly I have seen people recommend sickleservice. Can anyone comment on their products? Are they are good as Gen. IH? Obviously I would think a bit cheaper? which is good when you are buying 28 of them.
Thanks for the help with these guards or suggestions what I should buy! Mark
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
